Help for Haiti: Learn What You Can Do
Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > Main K20a.org Forum > Forced Induction and Nitrous K series discussion
Reply
Thread Tools
Old 04-03-2009, 01:50 PM   #1
SPL Dan
K20a.org Basic User
Default Stock K20Z1 Dyno
http://videos.streetfire.net/video/A...K20_644387.htm
100 % Factory K20Z1 Swap
K-Tuned Fuel Rail
Bosch Saturated 1000cc's
Aeromotive Regulator
Walbro 255lph
Custom Sidewinder
TiAl 44mm 11psi spring
TiAl 50mm BOV
Custom RaceRelated.com IC piping 2.5" Hotside 3" Coldside
Precision 750HP Intercooler
Precision PT67 .68 A/R E cover
Competition Clutch Twin Disc
Car came in with a street tune from someone on which it made 297whp on 12psi , I got it to 380 on the same boost level then turned the boost up to 13.5psi .
Car will soon be getting an RBC and headstuds going for 450 on pump then some C16 to have fun
__________________
Stock A2 93 CX 11.68@114.1 AM 10.67@131.9 DP
Simple Built All-Motor K24 331/228 10.79@127
94 EX Coupe 13.5:1 E85 2.4 on Nitrous
SPL Dan is offline   Reply With Quote
Sponsored Links
Old 04-03-2009, 02:04 PM   #2
1320WhtRex
K20a.org Bounty Hunter
1320WhtRex's Avatar
Default Re: Stock K20Z1 Dyno
Nice...
__________________
10.2@143
93 Octane
Stock Block
Tuned by Fred @HPC
New K20a.org HOTLINE
TXT us or leave us a message
(415) 343-k20a
http://www.importbids.com
1st K series CRX in Orlando, FL
1st Turbo K series CRX in Florida
Vouches and Feedback Thread ,
My EF Kswap Turbo Build Thread
R.I.P. Jose Rodriguez, Robert Mercado Jr.... We'll miss you forever... Gone but not forgotten
1320WhtRex is offline   Reply With Quote
Old 04-03-2009, 02:17 PM   #3
laggyb21
New Member
sick setup, im running 880cc injectors and similar setup but 35r, hoping for 450whp on 93oct on 1 bar. what trans are you running? if the 6 speed hows the lag treat you when you drive it in terms of shifting alot and the powerbands? im thinking of getting an ep3 5speed w/ lsd.
laggyb21 is offline   Reply With Quote
Old 04-03-2009, 02:42 PM   #4
SPL Dan
K20a.org Basic User
Quote:
The car has a Z1 trans in it now and it holds fine but the gearratios are a tad to short for our liking . We will be putting a 5spd in it soon .
With an RBC 450whp on 15lbs shouldnt bee too much of an issue as long as your setup is efficent
__________________
Old 04-03-2009, 03:01 PM   #5
archull
K20a.org Advanced User
archull's Avatar
yeah, the final drives we have on the 05-06' tranny (k20z1) is horrible. This 4.79 kills you on the track and its extremely annoying on the streets. I can't run a base tranny because I have a 06' Type-s and we have a different speed sensor, its countershaft driven instead of gear driven like the other k-series trannys. I am stuck with this tranny but I am lowering the final drive to something a bit more usable. I am going with the 4.3 final drive, quaife LSD & the TSX 6th gear.
Why are they using such a small A/R sizing on that turbo?? I personally would never go with anything lower than a .82ar on a k-series. These motors breath too well to choke them with that exhaust housing. Swap that out and your numbers should increase and in addition to the RBC you should see better power gains.
Similar setups to this (with larger a/r & rbc) are making around 430 @ 12psi on pump.
Best of luck with her
__________________
Great minds discuss ideas. Average minds discuss events. Small minds discuss people.
My Car Domain Site
Peakboost Turbo Kit w/ GT3076 Turbo 400whp & 280ft/lbs on pump partially tuned ;)
archull is offline   Reply With Quote
Old 04-03-2009, 03:22 PM   #6
JDMEG6
K20a.org Supporter
JDMEG6's Avatar
Does it ever piss the turbo guys off that you made the same numbers on nitrous builds . I might have to come up and see you I don't know if I can leave the spray side need a new setup. I do agree the exhaust is hurting numbers wonder what it would make with something bigger
__________________
K24A4 Pistons/Rods+Bearings (still assembled)
Make Offer
Old Setup, awaiting new times
13.357@109.722/
12.902@116.050 mph
best MPH 110.021...116.961
JDMEG6 is offline   Reply With Quote
Old 04-03-2009, 06:44 PM   #7
SPL Dan
K20a.org Basic User
This is the turbo the owner came in with . I did not choose it and he got a great deal on it so he wasn't going to pass it up . His TPS sensor was also acting up on the dyno not allowing the car to make full power we just installed it today once we put the headstuds in i'm sure it'll make more than 430 on the same boost level ...
I've done this long enough to know what these motors make lol . If you read the first post it says addition of an RBC coming soon
__________________
Old 04-03-2009, 10:00 PM   #8
BMFC
BMFC's Avatar
Looks good Jap. RBC will help that out greatly.
__________________
VOUCHES: civic5133,xproductions,buis02,nicersx,Captain Destructo,b18c,sik20,jwdearing,kpowerd 4g4d,94 eg
BMFC is offline   Reply With Quote
Old 04-04-2009, 12:11 AM   #9
RSX King
It's My Time
RSX King's Avatar
So no plans of a return or FPR?
__________________
Addicted 2 Ballen
RSX King is offline   Reply With Quote
Old 04-04-2009, 12:13 AM   #10
MikeyK20
New Member
MikeyK20's Avatar
sickkkkkkk, nice numbers, keep us updated!
__________________
Tu Madre Racing
MikeyK20 is online now   Reply With Quote
Old 04-04-2009, 04:44 AM   #11
poorboy44
K20a.org Basic User
Quote:
I believe they already have a fpr/return setup. At 22-23 seconds into the video, they zoom in on an aeromotive regulator.
__________________
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
You will be missed and remembered forever!!!!
poorboy44 is offline   Reply With Quote
Old 04-04-2009, 07:57 AM   #12
BlueHatch
K20a.org Supporter
Quote:
no, not really cuz we are faster
__________________
PM me for kpro/s300 tuning
9.23@164
www.clutchmasters.com
www.intrinsicperformance.com
www.tempestracing.net
www.saulsalceda.com
BlueHatch is offline   Reply With Quote
Old 04-04-2009, 01:05 PM   #13
SPL Dan
K20a.org Basic User
Quote:
Not on the street
Bring that 42R POS down here and lets run haha
__________________
Old 04-04-2009, 01:06 PM   #14
SPL Dan
K20a.org Basic User
Car has an Aeromotive regulator and return setup on it
__________________
Old 04-04-2009, 02:37 PM   #15
JDMEG6
K20a.org Supporter
JDMEG6's Avatar
Shhh you I meant stock blocks hehe. I need more spray or more boost, the race between you two would be sickness though do itttttt
__________________
Make Offer
13.357@109.722/
12.902@116.050 mph
Old 04-04-2009, 06:17 PM   #16
BlueHatch
K20a.org Supporter
Not on the street
if i had the 67mm setup still, id bust that ass
i went 9.90 on stock block. could of went faster.. shifting to 5th FTL
__________________
9.23@164
www.saulsalceda.com
Old 04-04-2009, 11:49 PM   #17
JDMEG6
K20a.org Supporter
JDMEG6's Avatar
I thought you had piston/rods cheater Jk you did tho no? I'll take shifting into 5th over blowing up these 6spds
__________________
Make Offer
13.357@109.722/
12.902@116.050 mph
Old 04-05-2009, 08:19 AM   #18
BlueHatch
K20a.org Supporter
no i had 110% stock block/motor with headstuds IPS kt1s and i also had ep3 trans
__________________
9.23@164
www.saulsalceda.com
Old 04-05-2009, 09:02 AM   #19
synik
K20a.org Basic User
synik's Avatar
How do you guys like those Bosch Saturated 1000cc's?
Assuming they are OEM Bosch, not ID Bosch Injectors.
__________________
DC2 k20a2 - GT35R
synik is offline   Reply With Quote
Old 04-05-2009, 12:36 PM   #20
JDMEG6
K20a.org Supporter
JDMEG6's Avatar
Fine you win happy now? . I need boost or a 175+ shot . Wasn't sure if it was completely stock block sorry bud
Dan you going to make a turbo setup? just add some spray to it
__________________
Make Offer
13.357@109.722/
12.902@116.050 mph
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
