Help for Haiti: Learn What You Can Do
Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > Main K20a.org Forum > All Motor K series Technical Discussion
Reply
Thread Tools
Old 04-03-2009, 11:34 PM   #1
KidnKorner
K20a.org Basic User
KidnKorner's Avatar
Default RBC Manifold vs RRC Manifold
Hey guys I was able to dyno a customers car before and after to compare the RBC vs the RRC (07 CTR) manifolds and the RRC made 7 more WHP over the RBC.
This manifold was installed on a 06 Civic Si.
His mods are
Injen CAI with Apexi Power Flow
Coolant bybass
RRC... not a RBC
P2R throttle body gasket
Hondata IMG
custom mandrel bent 2.5 with magnaflow straight through
Thermotec wrapped Vibrant RH
Unorthodox underdrive pulleys
ACT prolight 8.5lbs flywheel
Boomba Mounts
buddy club condenser
This is the baseline with the RBC and the power difference in these runs was the addition of 100 octane
This run is with the RRC manifold installed.
Disregard the torque spikes, they were due to a sensor error.
__________________
Ikuo Kajitani
KidnKorner is offline   Reply With Quote
Sponsored Links
Old 04-03-2009, 11:41 PM   #2
bossman032
K20a.org Supporter
bossman032's Avatar
Default Re: RBC Manifold vs RRC Manifold
Looks pretty good. It would be better if you could play with timing and cam angles. Looks like it has some potential of beating the rbc..
__________________
Wanna take birth as a DOG or Worm in stool?
You might be rich now or have it made, but to bad to sad that will not save your ass.
HAHAH, you just wasted your Whole God Dam life!
Just lived like A DOG! Good JOB!
A dog has some kids, so do you have some kids, a dog eats so do you, dog also sleeps so do you!
But a dog cannot save himself, but you can!
You just go signed up for another progressive step of birth and death fool.
Don't say I didn't warn you!
http://www.youtube.com/watch?v=9F5__7nC-SQ
http://www.youtube.com/watch?v=0SpA3p9GXlo
bossman032 is offline   Reply With Quote
Old 04-03-2009, 11:47 PM   #3
KidnKorner
K20a.org Basic User
KidnKorner's Avatar
The manifold even made a tad more power before the cam lobe switch.
__________________
Ikuo Kajitani
Old 04-04-2009, 06:49 AM   #4
Brooklynk24a
K20a.org Basic User
Quote:
Thanks for the post. Do you know what TB your customer is running? I wonder how you bypass DBW on older cars: EG, DC, EF, etc...
Do you have a picture of the manifold in the engine bay? I want to see if it has more hood clearance than RBC. Would this manifold bolt onto k24 head or does it have to be modified?
Brooklynk24a is offline   Reply With Quote
Old 04-04-2009, 08:59 AM   #5
ep305
K20a.org Basic User
ep305's Avatar
that's awesome!
i googled 'rrc intake manifold' and came across another forum who did a visual comparison between the rbc and rrc intake manifolds.
http://www.zerotohundred.com/newforu...omparison.html
does anyone know where to pick up an rrc intake manifold other than hmotorsonline.com?
__________________
03 civic si - k20a2 powered
ep305 is offline   Reply With Quote
Old 04-04-2009, 09:35 AM   #6
Mr_Plenty
K20a.org Master User
Mr_Plenty's Avatar
good information...
__________________
VOUCHES: HNAperformance--#2--civic5133--pb16b--onefstek-tuner04civic-civicmotorhead
Mr_Plenty is offline   Reply With Quote
Old 04-04-2009, 10:07 AM   #7
mike323
K20a.org Basic User
Something is not right with the air/fuel tables. The graphs look completly different. Did you play with the fuel tables during the switch to the RRC intake manifold?
Based on the air/fuel tables ploted, the conclusion that the RRC is superior to the RBC cannot be concluded.
On the RBC graph the a/f ratio is about 12:1 between 101 & 107mph, while on the RRC the a/f ration is about 13:1. It's obvious an a/f ratio between 13:1 and 13.7:1 is better suited on a natural aspirated Kseries engine at high rpms.
__________________
K24A2 EK Beast.
246whp & 180lbs-ft on a mustang dyno
With power steering setup, belt driven
mike323 is online now   Reply With Quote
Old 04-04-2009, 12:13 PM   #8
KidnKorner
K20a.org Basic User
KidnKorner's Avatar
Quote:
Originally Posted by ep305 View Post
that's awesome!
LOL, I see you have found a thread made by a customer of mine where they have reposted my post. THOSE ARE MY PICS!!!!
Also had you looked a little harder on this site you would see that I posted on here already with that info.
http://k20a.org/forum/showthread.php?t=55215
Quote:
There is a critic in every bunch, lol. The a/f tables are what they are. They are only there because the customer asked for them to be printed. These are just dyno runs, no tuning, or messing with any fuel trims were messed with.
The RRC has to be cut just like the RBC to be bolted onto K20A and CRV cylinder heads. Also there is no IACV port so users must introduce a vacuum source for idle control.
The manifold is a direct bolt on for any DBW car and the customer is using his stock Civic Si throttle body.
__________________
Ikuo Kajitani
Old 04-04-2009, 01:12 PM   #9
allmotora2
K20a.org Supporter
is the tb port 65mm? i thought i read the type r tb is 65mm?
allmotora2 is offline   Reply With Quote
Old 04-04-2009, 05:10 PM   #10
jdmspecdc5
K20a.org Basic User
a/f looks like it could be correct. if the manifold is introducing more air it will run leaner. the dip to around 12:1 a/f could be due to the maf and ecu trying to compensate.
jdmspecdc5 is online now   Reply With Quote
Old 04-04-2009, 06:12 PM   #11
mike323
K20a.org Basic User
Quote:
First of all, the ecu does not compensate when the engine is in full throttle, it uses all the fuel, ignition and cam angle all ready preset or programmed.
Second, we don't have a MAF in our K20s or K24s.
__________________
K24A2 EK Beast.
Old 04-04-2009, 06:24 PM   #12
mike323
K20a.org Basic User
There is a critic in every bunch, lol. The a/f tables are what they are. They are only there because the customer asked for them to be printed. These are just dyno runs, not uning, or messing with any fuel trims were messed with.
A critic and someone that pays attention to details.
If the RBC had an a/f ratio of about 13:1 to 13.5:1 it would of had about 3-4whp more, therefore the RRC would of only produced 2-3whp more than the RBC.
__________________
K24A2 EK Beast.
Old 04-04-2009, 07:28 PM   #13
KidnKorner
K20a.org Basic User
KidnKorner's Avatar
You guys kill me. All I can tell you is that the customer came to me one week to do a run with his existing mods then wanted to run his tank dry and try 100 octane.
A few weeks later he came back with the RRC I sold him and bolted it to his car and I strapped his car to the roller and dyno'd it.
I didn't mess with anything, there is no plug and play tuning for this platform. Read whatever you want into it, it is what it is.
__________________
Ikuo Kajitani
Old 04-04-2009, 09:24 PM   #14
jdmspecdc5
K20a.org Basic User
true. the ecu runs in open loop at full throttle.
btw we may not have a maf but the 06+ Si does.
Old 04-04-2009, 09:49 PM   #15
xproductionz
www.heyitsmikey.com
xproductionz's Avatar
if this is true then u dont have a true back to back run.. since he came back a week later anything could have happened to gain that power.. change in weather.. temperature.. humidty and so forth.. even the customer playing wit the settings themselves
alot could have happened in that one week to make a diff of 7whp... there is a margin of error thats why i can see where mike is coming from.. is this was a back to back run then yes i would say otherwise
__________________
Best Time: 16.8 @ 89mph
DIY: K20/K24 Swap into a 2001-2005 Civic
vouches: ronaldve, em2typeflex, ImportRace2123, ep3_u_see, 2000r#0283, hybrid racing, tsrperf, hondaluver, aznasinine, karcepts, em1, jskillz, suprfast, jeremy_almond, b20eg6.. and more
xproductionz is offline   Reply With Quote
Old 04-04-2009, 10:44 PM   #16
KidnKorner
K20a.org Basic User
KidnKorner's Avatar
Quote:
Like I said read WHATEVER you want into it.
run 1 74.92 degrees F 28.85 in-HG 17% humidity
run 2 75.35 degrees F 28.88 in-HG 16% humidity
run 3 71.06 degrees F 28.54 in-HG 27% humidity
Playing with settings, what settings would that be? His motec system exhaust?
This is a 2006 Civic Si, and there is no plug and play tuning solution for the vehicle.
__________________
Ikuo Kajitani
Old 04-04-2009, 10:48 PM   #17
bossman032
K20a.org Supporter
bossman032's Avatar
Not a considerable upgrade for a 2006 + si anyways.
But from the results it looks promising the upgrade
__________________
Old 04-04-2009, 11:43 PM   #18
k20addict
i'd love to do a comparison between rbc, rrc and any other oem honda manifold on the new tsx motor w/full vtc advance and proper tuning
__________________
I tune all high end Standalone ECUs
[b
k20addict is offline   Reply With Quote
Old 04-05-2009, 02:21 AM   #19
b20eg6
K20a.org Supporter
b20eg6's Avatar
KidnKorner, thank you for posting this. I'm not saying it made more power or it didn't, but thank you.
__________________
www.hybrid-racing.com
Pioneering the easiest way to swap a K20 into your car.
b20eg6 is offline   Reply With Quote
Old 04-05-2009, 05:51 AM   #20
Adam West
I don't know
Adam West's Avatar
What are the price comparisons between the two?
__________________
If you're gonna be original, you can count on being copied.
IPS
www.karcepts.com
Adam West is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
