VTC not working mechanically?
7.8K views 17 replies 3 participants last post by  eyecarvether4iam
#1 ·
So I am getting all the bugs sorted out with my car before it gets tuned, and am getting the wiring finished now. The VTC is not working. The tuner said it is all wired right and there is mechanical issues with it. When he adjusts the timing,(for example 30) and tries to make a pull. it spikes to 51 in the kpro, and the car shuts off. Is this the vtc sensor that has gone bad? I tried searching and could not find any answers. Have to get this thing off and tuned:cool:
#7 ·
What ECU are you useing, and what base calibration?
Do you have OBDII disabled?
It sounds almost like the ECU is performing the readiness test for cam cmnd, LOL.
BUT
For the VTC gear to advance it must counter the rotational forces of the cam and the only way that can happen is if oil pressure is sent thru the VTC solenoid. So either the VTC solenoid is damaged and allowing full pressure when activated or their is a errant signal from the ECU to force full travel.
Is your build a full 50 degree advance safe?
#8 ·
It is a stock CRV with ARP head studs. I did not think they came with the 50deg vtc.. (25?? like the accords, etc)
Setup is as follows.
08 Element(CAN BUS like the newer si's)
Kpro dual ecu setup with PRB kpro
Boomlang dual ecu harness rewired by a local tuner shop(don't ask the name, I am not trying to start an internet war)
Stock CRV block head to toe sans ARP headstuds
Vband 3076R turbo kit with fmic
The changes since the last tune are:
cable TB(was running dbw tb thru factory ecu)
new turbo manifold and downpipe(obviousluy not why)
oil filter relocation for the new manifold(oil pressure checks out)
boost by gear w/ lo/hi switch
speedo hooked back up(factory speed limiter is thru dbw TB, so we had to unhook it)
IACV wired in(having lots of idle issues and running pig rich at idle)
I was under the impression that the CRV motor was 50 deg VTC safe, correct? That is the general consensus correct(stock cams of course)
Not sure where to look from here...???
#9 ·
You should have no issues with 50deg cam advance.
Have you tried another VTC solenoid? Something is allowing the oil pressure to advance the VTC gear too far. You need to eliminate all the components one by one.
#12 ·
Not the spool valve, but #7, the VTC oil control valve.
The VTC gear assembly could allow 51 degrees, or the sensor could be off slightly, or their could be enough clearance between the parts and electronics to get to 51
